help way to hot!!!!
ok my radiator has a small hole on the top front.Is there any product that will fix it or do I have to get a new one.
the car never overheated until today and I looked and found a pin hole and no water:( that sucked. Will a plastic weld hold???please help I have to drive it monday and really need a cheap fix!!!thats :sad:
You could PROBABLY get by using any gasket sealant from Permatex. Make sure it can withstand extreme heat though. And are you sure, you’re leaking coolant from that area?
Regards,
Oz
jb weld … im serious its a liquid welding solution and it helps temporary… but i think you would have to change the radiator soon… because jb weld or any other product wont last for long
jb weld the crap out of it but scuff it up good b4 you put it on . it 'll last for a few months if done right. i had to get a new one eventually though from www.911radiators.com
:smiley: Thanks guys I slapped jb weld on after sanding the crack and then ruffed it with a file and spead the jb. after it started to set up I put a sandwich bag over it a smoothed it out after it dryed i took ok the bag and it lookes smooth.I drove it for two hours and no leaks hope it stays that way for awhile. Were is a cheap but good all metal or aluminum radiator shop?? any shops online would help thanks again:D
never put that stop leak crap in your system. it can eventually clog up. i guess a patch will do for now
i just went to the yellow pages & found an oem replacement (well, sort-of, it’s all metal), but i really wish i’d just gona ahead & gotten a fluidyne or c&r.
