Help with a Teg Tip
I recently went and tryed to rewire my foglights on my teg by using the Teg and its says "You’ll be concerned only with the fogs switch and the rear defogger switch right next to it. "
In my teg the fogs switch and the rear defogger switch are on opposite sides of my steering wheel. I was wondering if there was a misprint in the instructions ?.. if not why are mine indifferent places?
Thanks for any help
The teg tip is for LS/Gs/GSR. It is still the same except you use a larger wire. Run wire behind steering wheel (behind the rubber cover). And don’t forget the butt conectors :gay:
