So I have a TON of oil leaking into my spark plug holes so I’m going to replace the seals under the valve cover, however I’m noticing a TON of oil leaking onto my drive way. Could I actually be leaking that much from the spark plug holes that it would drip down all over everything? I can see it all over the oil filter down to the pan. I was hoping it was just a loose oil filter but that’s on there pretty tight. I just de-greased my engine with the spray stuff and I have a gas powered high pressure hose and blew EVERYTHING off of my engine so I can maybe see a bit better where it’s coming from. Any suggestions are appreciated!
O, and are Acura gaskets way better than cheap azz autozone ones? Cuz the spark plug gaskets are like 3$ a piece and the valve cover gasket is like $12. And i’m just ASKING so dont tell me i’m a cheap azz!!! ![]()
