i’ve read as many posts as i could about freelog and crome here at g2ic, and all i see is that a few people get them to work great together. well i can’t…
i’ve been tuning the last 2 days by watching my a/f on logworks and noting when i’m rich/lean, also noting about what psi i’m at and about what rpm’s im at doing 40-80 pulls. then in crome i adjust anything in the corresponding sections of the rpm and vac/boost on the maps and charts, adding/subtracting fuel where it looked higher or lower. got myself into a much safer zone, but it sucked looking at 4 things at once.
my problems:
-freelog shows something that looks like data…some readings i’m not sure of but don’t look right, rpms are definately off (do i need a rpm attachment? can i diy one), map reading is right however. also the boxes in the charts and data capture didn’t do anything but change color and it was about half the chart?? i didn’t try the “log” button, it just didn’t look right so why log garbage?
-how do you set the target lambda tables?? read something about “uploading” the tables?? i can’t find any. could this be why i’m not getting my o2 readings?
-cromefree works fine…i did have trouble getting it to work with the rtp, so crome adjusts everything, i save my change then i load it in tunerpro rtp and put it on the ostrich 2.0, works fine, but i’d like to just use crome.
-and is there any way to write plugins for cromefree or freelog?? i am wondering why there isn’t one for datalogging or something that someone has come up with, unless i haven’t found it. i’m also wondering about plugins for a launchcontrol or 2step, i believe i’ve seen them but do they work with cromefree?
hopefully in the next few days, i’ll work some stuff out or i’ll get some helpfull info.
