Help with HID Kit Conversion
Okay I have a 91 Integra and i Got a hid conversion kit the only problem is that its for a 9006 (94-thru Integra) how would i hook it up to my car
you dont haha. where did you get the kit? you can always order replacement bulbs on ebay for cheap. and just use your ballast that came with your kit. just make sure to specify with the seller what bulb and color you want.
http://cgi.ebay.com/ebaymotors/HID-XENON-BULBS-D2S-D2R-H1-H3-H4-H7-H11-H13-9006-9007_W0QQcmdZViewItemQQhashZitem53de9a21a8QQitemZ360216928680QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Installing a HID Kit on your vehicle can save you a lot of money. If you have a car of 2000 model without a closed beam, then it is less costly to convert to HID headlamps. You can also install the lights on your own. However, it would be better to hire a reliable mechanic to install the headlamps from your HID Kit if you have limited knowledge regarding electronics and automotives.
yea i plan on doing that for the time being i just used female and male contectors works fine
