help with high beams and fogs
hey guys when i turn my lights on the fogs come on as well. well thats fine but when i turn the high beams on the fogs shut off anyone else have a problem like this?
The fog lights only work when low beam are on. 94
ok…another question does it seem when you turn your brights on it get darker?
i also need help with something involving fogs,
Sometimes my fogs work and sometimes they dont, and when they work, it will work for only a little while and then they will shut off, What do you guys think it may be, the switch or the wiring?
If you mean directly in front of car, that would be normal.
Do you have a multimeter or a 12V test light?
First thing I would do is replace the fog light fuse, [fuse 19 - 15A] hot at all times] in under dash fuse box and yes, even if it looks good, or it tests good with the meter or test light.
You can also try giving the fog light relay a few good “taps”, if fog lights “flicker” on, replace the relay.
For any more testing you will need the meter or test light. 94
[QUOTE=fcm;2105144]If you mean directly in front of car, that would be normal.
For any more testing you will need the meter or test light. 94[/QUOTE]
thank you, will try tomorrow.
