Help with JDM 1pc
I have a set of Stanley 1pc headlights that I picked up for cheap.
My question is, how can I wire them up to my DA?
I have some H4 connectors and was wondering if I can use them with H4H light bulbs…
Searching is a good thing. http://forums.g2ic.com/showthread.php?92984-JDM-1-Piece-Install-step-by-step&highlight=1+pc+head+lights or http://forums.g2ic.com/showthread.php?162064-Turning-h4-s-into-h4h-s.
There ya go.
[QUOTE=teg cruzr;2247407]Searching is a good thing. http://forums.g2ic.com/showthread.php?92984-JDM-1-Piece-Install-step-by-step&highlight=1+pc+head+lights or http://forums.g2ic.com/showthread.php?162064-Turning-h4-s-into-h4h-s.
There ya go.[/QUOTE]
Thanks, but that’s not really what I asked. My question was if I can use H4H lights on H4 connectors (from a 92-95 civic)
My headlights didn’t come with connectors, reason I got them for so cheap. I know I can modify both H4s to fit the housing or the housing to fit the H4s.
Ah…well, I’m not postive on that. I figured between those two threads an answer could be found.
The answer is yes. I just replaced the plugs on my 1 piece. I bought some h4 harness on eBay and they work perfectly with the h4h bulbs.
Thw connectors are the same for both bulbs just the base of the bulb and position of the filament are diffeent
Thanks guys, I really appreciate the info.
