hey guys, my b17 unfortunately is wore out and due for a rebuild. so i have elected to swap a b16a2 in to it until my rebuild is finished. please do not suggest other engines. my thought is if i swap the b17 and intake mani to the b16 head i should be able to use my b17 harness right? i may just end up having an extra sensor or 2 on the block that wont get used like the crank fluctuation sensor? any help would b appreciated.
its a 92 btw, i kno there were slight differences with the 91 and 93
bump
Were you able to get it sorted out? You should be able to bolt the b17 intake manifold to the b16a2 head. Just reuse your fuel rail and or injectors and it’ll all plug into your harness.
