as its says in the title im running in to a problem mounting my harnesses in my 4door. i have the lap belt and anti-submarine belt mounted its just the shoulder belts. they are not long enough to run to the rear seatbelt mount any ideas.
Unless you can fab a harness bar there’s no other mounting spot which is safe and further forward than the rear shoulder belt mount locations.
i figured as much. do you know where the Canadian seat belts mount to for the front seats, i guess i could start there for a harness bar.
They mount right exactly where you think they would, right there on the B pillar. If you remove the pillar covers there should be a hole where the manual seatbelts are normally mounted. Unfortunately it’s just a hole and it’s not a threaded piece of metal. So welding will be required.
aight cool. thanks
