help with tails
i searched and found the way to clear the pink lines on 90-91 tails, so i was doing this process with a heat gun and it was a complete mess, i tried pulling and all it would to is stress out, then after a few minutes of heating it was geting to hot then i pulled apart and bam they broke right in half, is there any other way to remove these lines without taking them apart? aka a chemical that takes them clean away?
Apparently you didn’t search hard enough.
http://www.g2ic.com/forums/showthread.php?t=114284
