Help !!!!!!!
ok, the tach, fuel guage, passenger passive belt, blinkers, the clock, and temp gauge are not working. If its a short how should i go about fixing it, all the breakers seem in tact.
fuse it sounds like one of the fuses. it’ll be under the dash board and look for the number 23 it’s a 7.5 a. The cover that you are taking off should have a map for it. there should be a fuse puller use that and look at the 23 fuse it most likely is burnt and then replace one with the back up ones on the side. Let me know if this fixes it.
