Help!!!!!!!!!!!!!!!
Iam in the need of some help CEL and it is saying knock sensor i have GSR motor with b16 jdm ecu i want to know what is the pin on the ecu for the knock sensor
http://www.g2ic.com/forums/announcement.php?f=14&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
