Just got my car towed a few mins ago. I don’t know what went wrong, so i’ll just ask you guys.
Okay so here’s what happened. I took my lil bro to get a haircut, but unfortunately the barber shop was closed. My lil bro and I went for a cruise. Just around the block. Then we came to a stop light and when it turned green. I floored it. Second gear. Then third and thats when it happened. It didn’t go into third. Also my clutch pedal sank and didn’t rise back up. So i pulled over to the side. Checked everything out. Everything seems to be okay, but then when i put it into gear it goes in and all. It just doesn’t go no where so what could it be guys? My friend said it could be because i snapped my axle. I don’t know but i want it to get back on the road since its how i get to school.
EDIT: I am still able to start the car. and the clutch pedal doesn’t sink anymore. It comes back up just doesn’t move ):
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
ALSO
POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. ASKING IF A PARTICULAR PRODUCT IS GOOD SHOULD NOT BE POSTED IN ASSISTANCE, BUT RATHER IN THE PRODUCT REVIEWS FORUM. You may NOT post in the General Discussion forum (or any other wrong forum, depending on your subject) just because you think it will get more attention and you’ll get your answer sooner! Read each forum’s or category’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
