im not sure if its just my car but when i turn on the headlights i would say 7 out of 10 times both lights turn on with no problem. but the other 3, only 1 will turn on and then i have to fiddle with the wire under the hood to get it to turn on. and its always the passenger light, the driver side never gives any problems.
i checked the wires and there isnt a short or anything like that. i have no idea what the problem is…
is there anything i can do so that i can eliminate this problem?
which hid kit do you have?
i had the same problem. it turned out it was my ballast. i changed the ballast and havent had a problem since. try putting the working side bulb to non working side ballast and vice versa. but my problem was just the ballast. hope you get your problem situated
get a relay harness, it’ll solve your problem
Do you have any links or anything to show the proper way to hook one up?
[QUOTE=uniqueillusi0nz;2156905]http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/141578-how-hook-up-relay-harness-your-hid-lights.html
hope this helps a lil[/QUOTE]
helps a little? that helps a lot. in fact, it helps so much it solves my problem…
thanks
no problem. post pics when your done
