High Beam Burnt Out...
Hey, I have Eurolite Extreme headlight 9004 bulbs… yeah I know theya re cheap. anwayys I noticed today the high beam on the right side does not work when I flick it on but the normal driving filament works fine. the left light bubls is eprfectly fine. question is, if I accidentally did touch the bulb with my fingers, woudl it have caused this? or would touching the glass part jsut blow the entire thing? I do not recall touching it with my figners but Im jsut maknig sure to see if it’s jsut that it’s cheap bulb and the filament burnt out cause it’s cheap… btw, they are only about 2-3 weeks old.
Mine did the same thing… when I took them out, there was big burnt part on the globe… looks as though they were hitting on the bottom on the light, causing a hot spot. And the stopped working. Replaced with OE Honda globe, no problems since.
