high beams stay on all the time
ok so yesterday i got my black housing one piece EbayDM headlights to replace my ugly ass halos. all went well in the installation. it was straight forward, unplug, plug back in, wire fogs, voila. but the only problem is on my dash my high beam light stays on. the headlights do cycle between low beam and high beam but the light stays on all the time. can someone help me out on this? its getting very annoying TIA
Did you replace any bulbs?..Maybe make sure the bulbs are securely in there. The headlight casing shouldnt affect your high or low beams either way I …Just the bulbs. Cant imagine how your fog light wiring could affect your hi/low beams either…
My guess is a loose/bad bulb or somehow when you say “wired in the fogs” you messed up?
Just a guess tho :slight_smile: I dont know much about electrical.
Have you tried plugging your old headlight in again and see if that does anything?
i did replace the headlight bulbs themselves because the new headlights were 9007 and the old were 9004. i cant plug my old ones back in because they were thrashed the day i got my new ones. and i culdnt have messed up the fog wiring because it was simple, red to red and black to black. and all of my fogs work
This has been covered many times… SEARCH!!!..
Since the ebayDM headlights take 9007 insted of stock 9004… There are two out of the three wires on the the back of the headlight plug that you have to cut and switch…
Search for the 9004 to 9007 headlight conversion… There’s a really good write up and it’s very easy to do!!!..
thanx. and i tried searching but i didnt know what key words to look up
repinned the harness and all is good, thanx
