Hmmmnnnn... Interesting headlight help needed
I have had my one pieces installed for at least 6 months now. So the other day I pulled up at my friends shop and got a parking space directly infront of the store window and was looking at my lights reflection in the window. So I figured that it would be a good time to see what is up with my brights since they seem to work funny for me. It seems as though one is on bright and the other is on low and when I switch them from low to bright they switch out, the other one is bright now and the other back to low. Lets see if this makes more sense… I can see the hot spot of the beam only on one light when on low beam and after I switch to highs the hot spot switches over to the other light.
What side of the car I am sitting in makes no difference. Is it possible to have installed the actual bulb upside down?
umm not unside down bulb… u got the wires mixed up.
Re: Hmmmnnnn… Interesting headlight help needed
Highly doubt that your bulb is upside down. It’s made to be installed one way. The tabs are not equilaterally spaced out. You might want to check your wiring, you may have mixed your wires around.
Regards,
Oz
