Hey guys, I bought a v1 Hondata s300 installed in a p28 from a friend. I also have my original P61 with a s100 installed. When the car is cold or the ECU, it takes an average of 20+ mins for the red light, visible through the USB port, to go green. At that moment, I can hear the fuel pump prime (fuel pressure guage shoots up to 38 psi) and I’m able to start the car. After the car is warmed up, and I drive it around for a little while, the green light comes on seconds after I turn the ignition on. If I let the car sit for a while, I’ll have to wait longer for red light to go green…it seems the longer the car is off, the longer it takes for the light to turn green. If I swap out the S300 equipped ECU for my P61 w/ the S100, it starts up every time, even after letting the car sleep for days!
I’ve replaced and added extra grounds to and from the chassis. I’ve clean, added and secure the grounds on the thermostat housing. I have no other electrical issues with the car nor do I have lit engine check light. After reading this thread…I’m now thinking it may be a faulty capacitor that is not holding it’s charge? Is that possible? I’m at my wits end on this one. I think I’ve reached the end of the Internet ![]()
I had the capacitor replaced and all the pins for sockets resoldered…but I’m still having the same issue (I have to wait over 20+ mins for the solid red light on the S300 to go green after the cars is off for any length of time). My only option now is to do as suggested in a post on Hondata’s forum and get a new ECU socketed for the S300.
Note: Prior to replacing the capacitor, I took my ECU over to my friend house and connected it to his Integra, a 95 RS. When I first turned the key, there was a 2 second delay before I got the green light.
After about 20 mins being plugged in, I removed it and brought it back home and reconnected to my DB2, and to my surprise, the damn thing went green as soon turned the key on. It seemed like the capacitor got charged up while it was plugged to my friend’s car.
Any help would be appriciated. I’m in the market for a virgin p61 pr p28.
