And… What did you figure out?
I’m going through this same issue right now, but it seems to be getting worse over time. The hood is sunken in on the passenger side, and raised on the driver’s side. You can see the washer fluid cap from the outside. I’ve tried adjusted the latch with no luck. I haven’t touched the radiator, but I’ll check it again. Any other thoughts? It’s weird that it’s just slowly getting worse like that.
I’m not sure how, but adjusting 3 blots on the latch worked somewhat. I’m still high on the passenger side a bit, but it’s level with the frame on the driver’s side. I actually think it has something to do with the wiper arms and I also noticed that the hood seems to be misaligned with the frame near where the hinges are. I must’ve jostled something good a while back! Perhaps between those things it’ll finally lay properly.
