how big of a pain is it to change the master cylider?
i’ve had my integra for about 4 days now and it has become very apparent tht i need to doo all of the maintenance stuff that the last owner neglected to do. first off i need to change out the master cylinder, mine is cracked, and i have no idea where to start. the one in my civic was easy enough to do since there was a lot more room to work with (no power steering) is there anything too look out for and what can i safely remove (and put back without harming it) to gain a little more room to work.
It is not too hard only time consuming bleeding the brake lines.
Shouldn’t take more than an hour to complete if you have a air powered vacume pump, If your doing it by hand (hand pump) add an extra hour.
There were several posts about this, run a search and you will find some answers.
