how do u diagnose CEL for 90-91 integra?
i searched… nothing …
im checking for codes and redo my timing. can someone help?
Search harder.
http://www.g2ic.com/tegtips/engine/13.html
Countless threads on this.
there is no shorting a connector needed?
how about using a timing gun? do i need a diagnose terminal to be shorted?
You will need to short (jump) the connector before adjusting the ignition timing with a timing gun. Also remember that the idle must be at 650-700rpm when adjusting.
Do you even know what you’re doing?
i more familiar with obd1/2…
also more with Toyotas…
