how do you know when its time for a valve adjustment, i think i might have symptoms cuz when i listen to my engine closely it sounds as if somethin is loose in the block…i dunno
Re: How Do You Know…?
typically its time for a valve adjustment if the valvetrain is getting loud. It will be a sort of ticking sound. oh, and so you know… the valves aren’t in the block. so if the sound is coming from the block, its not valvetrain.
doing the valve adjustment is super easy. Just need simple hand tools and some feeler gauges (make sure you read your manual). it can’t hurt to check the valves clearances.
