how much coolant?
how much coolant does it take to fill a stock 93 gsr radiator ?
as much as it takes to fill up…Just grab two bottles of 50/50 fluid. It will take about 1 and 1/4-1/2 bottles
the entire system hold 6.1 quarts. which is a gallon and a half.
buy a gallon of straight coolant and then you’ll have enough foir what ever you do
dont just use straight coolant use 50/50 or dilute the straight coolant (50/50 ratio)
He said, “buy a gallon of straight coolant and then you’ll have enough foir what ever you do”. That is correct, you buy 1 gallon of straight coolant, mix it 50/50 with water from your house, and you now have 2 gallons of 50/50. Its also cheaper to mix your own.
He never once was it said to put straight coolant into the car. Unless you want to mix it that way. We know the car takes 1.5 gallons of coolant at 50/50 ratio.
Pour .75 gallons of straight coolant, and .75 gallons of water, and you have a 50/50 ratio. Your car’s coolant system mixes it for you.
