how much would i look to pay for a new 3rd gear and syncro for a gsr 92 93 tranny
thanks
ask BR…
WERE YOU HAVING THE SAME PROBLEM AS I AM, 3RD GEAR ALWAYS GRINDIN, MOSTLY WHEN YOU SPEED SHIFT?
yea 3rd when i speed shift reallllllllllllllllllllllllllllllly iritates me
by the way, do you happen to have an aftermarket clutch, just curious
I’ve got the whole gear set from a 92-93 gsr. They were on the tranny for about 19,000, but then the tranny crack because my friend hit a bump, so now I have the gears and they are in excellent shape. give me an offer, will not part out.
how much do tou want for the gears.
I also have the third gear problem and so does my roommate. Part of it has been said to be the short shifter. Mine is fine when you first start her then 10 min or so later in kicks in.
-A
when you grind when shifting is it just hurting the gear or is it hurting more like the flywheel or pressure plate, just curious i dont know much bout trannys
http://www.howstuffworks.com - go to ‘how manual transmissions work’… its not the actual gears that are grinding…
its your synchos
Retail price from Acura is $278 + tax. That is for the 3rd gear set (3rd gear, both synchros, both synchro hubs and both synchro rings).
Later,
BR
