[HOW?]Takin off interior door panels?
hey all
i noticed that when i turn up my HU a bit w/ the bass dba upped
my front passenger door starts to vibrate around where the lil “arm support” is, u know the place on the door that sticks out a bit and dips in to carry stuff (lol i know kinda bad descript)
anyways
all i have in the car is 2 front 5 1/4" pioneer speakers, not the greatest but still enuff to cause the door to vibrate
i noticed that when i do turn up the music a bit if i push in that “arm rest” it stops, so i’m think in if i take off the panel, then i can see what is vibrating.
so anyways
can u guys tell me how to take off the interior door panel?
oh ya i’m runnin a '90 4dr RS
thanx in advance
  • Juice
First take off the screw at the handle by the lock button, then all the screw you could see. After all the screw, you wouldn’t be able to move it yet until you pull all the clips from the bottom side of the door. Just stick a screwdriver on the botton side and pull. They will pop. Then after all around is popped, then the top part where the window is, there is a clip that clipped really tight. Use screwdriver to undo the clip. To do this you need to pull the door cover(bottom side up a little) so that you could see how the clip is position. After the clip is undone then push the door cover upward toward the sky. I hope that helps, sorry for the unprecise language. If any question, pm me. Thanks!
also there are hidden screws with a cover over them. i had the same problem on the door. i heard a little rattle then i tried to figure out where it was. it was right in the thing u said. the little ashtray look a like thing. it was the piece of metal on the inside. u can see it if u take out that plastic thing. i just took the door panel off and placed some rubber washers (ones found inside gardening hose) between it and the door. so it wont hit the metal. then i never heard the rattle again. not so sure if its the same for your car, but it should be similiar. i got a 92.
