Well this is a little weaksauce but I’m far to cheap to buy a JDM clock when I can make my own for a 1/4 of the price. So laugh and poke fun all you want.
Disclaimer: As usual, you do this mod of your own free will. If you screw up, it’s your fault.
List of materials:
#1 flat head screw driver
Tamiya clear orange paint
foam brush
masking tape
Step 1: Take the clock out. I used my key to do this. Slip the key under and pop it out. Undo the connector at the back. Here it is out of the car.
Step 2: You need to take the clock apart. Start by removing the silver tabs on the side.
Then undo the 4 black clips, 2 on top and 2 on the bottom.
Now you can pull it apart.
Step 3: Mask it up with masking tape.
Step 4: Get your paint and foam brush and paint the clock. I did 2 coats.
Finished.
Step 5: Reassemble the clock.
Step 6: Put it back in the car. Pics are at night because I did this late at night.
Lights off:
Lights off:
Enjoy and flame away at my cheapness.
I did this so it will look better with the S2000 cluster I’m swapping in.
