how to clean your window switch w/ pics
OK, This is my first write up. So bear with me. . .anyways you will need
you will need;
  1. phillips screw driver
  2. small flathead
  3. tweezers
  4. i used a shop rag, but any kind of towel rag will work
So basically were just cleaning the contact points. You could use a cleaning product if wanted. . i Didn’t personal opinion. . .
you wanna start out by taking off the the phillips screws. . .
peel back the plastic boot
i started by removing the passenger switch, i used the small screwdriver to pry very gently.
these are your metal contact,this is where the tweezers come in handy. pull these off. . .don’t worry they are interchangeable
just showing how dirty the uncleaned side is, take the rag and clean off these contact points.
then what i do is check the grooves and take my metal contacts . . .and put the bigger one on the more grooved section. . . so the contact is better. . .
onto the master side, pull the pin. . . BUT be carefull they are spring loaded
pull your metal contact and clean them good’
then clean the contact points the best you can with the rag. . .or the “black stuff” in the teg tips. . .top and bttom. . top cleaned, bottom is not
then like i said check the metal contacts, and see which has a bigger contact patch. Well patch still intact and place that on the more worn out area. . to kinda even things out. . .
well hope that is a lil better information. . .and if this is already covered i’m sorry
sorry about the bad pics
Can you rewrite the stuff that says “remove this thing in the picture” cause i have no idea what the “thing” is. I got sticky window switches, but I only played with the visible copper things. I’m not sure how the internal metal contacts, or black stuffs, look like.
can you re-take like…all the pictures?
lol
scratchy, the metal contacts are what make your window go up and down . . .and the black shit is what makes your switch “sticky”
ez12, it’s hard to get the camera to focus on that small shit anyway. it’s just supposed to be a general overview to help you along. Before you dive into something and fuck something up.
and as for the closeup’s they are only showing a cleaned side and a dirty side.
Now I Know I Need Glasses.
If It’s A Digital Camera Put The Flash Setting On Macro… And Possibly Put It On A Tripod.
haha. thats exactly what i was thinking… if u use a Macro feature, u can take pics like this:
that is a 3/16" brake line flare.
wow pics are horrible. cant even see a thing. try messing around with the settings to see if that helps.
please please retake photos i need to do this asap
http://www.g2ic.com/forums/showthread.php?t=179674&highlight=window
I did it. Better pictures too.
