How to de-pin connectors
How is it really done? With a small flat tip screw driver? Go from the front or back?
If I’m not mistaken, you would insert the screwdriver into the front and pull the wire out from the back.
using a prying motion? to loosen something?
on most connectors there will be a plastic clip over the metal end on the wire similar to the one that holds the actual connector together, so you need to pry it up while pulling the wire out.
nice been looking all over forums for any info. Thanks
can you attach those pictures so we dont lose them on here?
