how to easily remove door handles?
wanted to know the best way to remove the door handles… unscrew the 2 bolt that hook it to the door from the inside? do I have to remove the window tray or I can reach and unbolt these 2 bolts…?
thx!:slight_smile:
You can unbolt the two screws fairly easily. The little metal bars that go from the lock and handle to the latch are not fun to remove and re-attach though. You need small hands and LOTS of patience.
Good Luck
thx, I’ll look at it tomorow:)
the bar is pretty easy to remove though-just slide the clip one way and the bar will pull out. The hard part is putting the bolts back in
