how to fit WW front bumper
Hey guys,
I came in contact w/ a Wing West Big Mouth front bumper for a 90-93 Integra. I just don’t see how to fit it on…it had holes on the top like the bumper support should be in there…yet it would be useless to put it on cuz there is no advantage…out of all the holes wheres screws should go & other shit, the only ones that match are right in the wheel well under the fender. no other holes line up or seem to even go anywhere…
now take into consideration i also have a 90 & it says for a 90-93…i thought the 90-91 bumpers were different from 92-93…also i have a DB1(4dr) not a 2dr…
there are holes under the bumper like they should attach to the bootom of the frame or something, where the OEM bumpers bottom did, but it obviously won’t reach, there are also holes ontop of the bumper that looks like it should be fit to a bumper support or attached under or near the headlights…
i even took off my headlights to see if i was missing something…can any1 help me w/ an online tutorial or how-to with this bumper? or is it just not for my car…
Mine fit fine on my 90 when I had it. :shrug:
is the front bumper assembly/attachment different for 2drs & 4drs?
Mine fit perfect as well when i had that bumper. I only used the 3 holes in the middle (none under the headlights) and the 2 in each wheelwell. Should be the same for 4 door. Mine is a 90 as well.
Sorry to steal the thread but what wing is that?
well…i took pics to help say what i mean…
pic showing it’s a big mouth front bumper
pic showing holes in the bm front bumper from a side view
top view of holes in center of bumper
pic of chassis w/ bumper & headlights off including headlight bracket
so what i’m saying is where do i attach the bumper to besides the 2 holes in each side of the bumper that goes into the wheel well under the fender? i know there are no holes in the headlight brackets that would allow the bumper to attach to the headlight bracket…so where/how does the bumper attach to the car?
Bumper support
I see where you problem is. You think the bumper goes right on after you take of the oem bumper but it dosen’t. What you need to do is take the bumper support of the factory bumper and use it on the new one.
best way to fit a body kit = leave stock bumpers on and throw body kit in the trash :slight_smile:
i was thinking that…but then what are the holes for on the top of the bumper? or did the previous owner put them there? also has any1 taken off the bumper support from their OEM bumper & put their bumper back on w/o the support? besides having a problem if u get in a crash are there any other problems w/ having it off?
The holes on the top bolt onto the bumper support. This really isn’t that difficult. If you having this much trouble, take it to a shop and have them install it.
If you have no bumper support, then you have no bumper cover since you need it to bolt on the bumper cover.
well i will go try ti & tell you how it goes
