Okay, you get springs, and you have to get struts, correct? No, I am wrong!
Here is what you need:
-Tap and die set
-something to cut the strut rod
-and of corse, the normal tools
Here is what you do:
You remove the strut and spring assembly, then proceed to remove the spring. Thread the Die down onto the threads. take the die down about an inch futher than OE spec. cut enough excess off to be able to cloce the hood, the unscrew the die (to correct the threads). Put your spring back on the hand tighten the bolt w/ about 1/2 in excess, or use a vice grip on the rod and tighen it and create weak points in the strut rod. Put the strut/spring assembly back on, and the assembly should be tight. Volla!! you now have full complete tavel of your strut! You now run a 50% lower risk of blowing your struts, and making your ride better than it was before. (results MAY very)
