how to hook up sound for a ps2?
i have a sony explode deck and i dont have any input plugs to plug ps2 sound into. so how do i hook the sound up then?
If i’m not mistaken, the PS2 has 3 outputs Video - Yellow, Audio - White & Red (for left/right).
You should be able to just connect the white+red from PS2 to your AMP stereo inputs.
Probably easiest is to use an fm modulator. A lot of tv tuners have one built in, so if you have a tv tuner, you can plug the ps2 into the tuner and then hear it through the stereo, see it on the tv. Most electronics places should have fm modulators. None of the antenna based ones seem to be perfect though (I’ve tried a few, they all worked about the same, but they weren’t fantastic, due to some interference with radio stations). You might need an adapter or two to convert from the ps2 rca plug into a modulator, but you should be able to get something at radioshack.
thanks. peeps
