Hey I just bought si side skirts and was wondering how to install them and if there’s any write ups or pics thanks
no one?? i did a search and didnt find anything thanks
here u go
here are the steps:
- cut the TOP PIECE of the ek side that would go inside the ek door: draw a line from end to end to make it straight
- cut all EXTEND AREA PIECE of the bottom of the ek side to make it flesh
- line up the ek side from back to front next to the side of the car to see if its flesh: make ur marking to cut the front piece
- option: i use the orginal holes on the bottom of the ek sides and drill holes under the car to mount them: and u can also drill new holes to make it stronger
- u should be done after these steps…
option rear lip: u could use a 94-95 honda accord rear lip… looks awsome… but the rear lip needs to be moded also…
here you go buddy
http://www.ozhonda.com/forum/showthread.php?t=45016&highlight=lo_n_sxc
Is there any other way beside drilling holes in the chassy to get it to stay there?
You can also try industrial strength 3M double sided tape…
