i know everything is plug and play but the problem i run into is how to put the hid bulb in the headlamp socket and make it stay cuz the ring u use on the factory 9004 bulb doesnt fit…please help me thanx
pull out that circle washer where the bulb goes…thats what i did with my 1 piece head lights…gl
do you have jdm 1 piece headlights? if you do you need h4h bulbs.
the 9004 bulb WILL NOT FIT in the jdm headlights… they are meant for the USDM 3 piece glass headlights. i’ve heard of ppl on this forum modifying them to fit… but why go through that headache?.. simply buy H4H HID kit… thats what i did… they are the same price
do you have an hid kit made for the 1 peice?h4h bulbs? if you got the h4 hid kit then your screw
Nowhere in his post does it say he has one piece headlights.
As long as you are using factory USDM 3 piece headlights the 9004 bulb will work and it goes in just like a regular bulb. As far as the ring not fitting, and by ring I’m guessing you mean the black plastic circle that holds the bulb inside the headlamp, you have to unplug the bulb from the ballast and slip it over the wires that way you can still use it. I think that’s what you are talking about, if not correct me.
thanx for the help i got it under control
