First off this is mainly for the people that have to hard wire it in because the original wire harness was cut! Anyway get a RSX cd player and the readio harness with at least 6 inches of wire!
Cut the ends of all the wires off of both the Integra radio harness and the RSX radio harness! Then strip a piece of the end on all the wires on both harnesses!
Choose the connectors that you are going to use! I used cruch connectors, to save soldering time!
Match up the wires from Tegs harness to RSX harness!
90-93 Integra Radio Harness
-Right rear speaker (+) = Red w/Yellow stripe
-Right rear speaker (-) = Brown w/White stripe
-Left rear speaker (+) = Blue w/Yellow stripe
-Left rear speaker (-) = Gray w/Whit stripe
-Left front speaker (+) = Blue w/Green stripe
-Left front speaker (-) = Gray w/Black sripe
-Right front speaker (+) = Red w/Green stripe
-Right front speaker (-) = Brown w/Black stripe
-(+) 12 volt battery wire = White w/Blue stripe
-(+) 12 volt ignition wire = Yellow w/Red stripe
-Ground wire = Black
RSX radio harness
-Right rear speaker (+) = Pink
-Right rear speaker (-) = Blue w/Yellow stripe
-Left rear speaker (+) = Blue w/White stripe
-Left rear speaker (-) = Blue w/Black stripe
-Left front speaker (+) = Green w/Black stripe
-Left front speaker (-) = Light green
-Right front speaker (+) = Green w/Yellow stripe
-Right front speaker (-) = Gray w/Red stripe
-(+) 12 volt battery wire = White w/Red stripe
-Illuminated button power wire = Red w/Black stripe
- You are going to have two wires from the RSX harness that will go to one wire on the Integra harness! The I 12 volt igniton wires [/I]will go together along with the Illuminated button power wire on the RSX harness!
Here are some pics to help!
