How to Open Up Clear Tails?
I just got some brand new clear tails off of e-bay for $35 shipped. I want to mod the sucker but I need to take it apart. Has anyone attempted to take apart their clear tails? Before I use the same technique as posted for the stock tails (in the Teg Tips section) I want to make sure the same procedure works for the clear tails.
I’m hesitant to try it because it seems like they used some kind of hardened putty to seal the clear tails.
Thanks in advance for any help.
I put my into a warm oven to heat them up, then gently pried the plastic off… unfortunately, mine cooled down too quickly and I cracked the plastic… I think you might to keep warming them, cos the putty is very stiff when cold. But when warm, it stretches good@
Good luck!
Yes, The Oven is the way to go… i know many people whoi have sprayed the inside of there headlight…
just bake it for a while,…
just make sure that if you use high heat, you pull it out quicker…
