How to remove headlights/bumper?
I want to remove my headlights, but am having some trouble doing so.
I removed the 3 bolts into the black metal bracket holding the headlights, but they would barely move. Where else are they bolted in? I tried removing the corner light too, but that didn’t help at all.
In addition, what does removing the bumper take?
thanks,
-Daniel
take the bottom turn signal lights off. in there you should see 2 14mm or 12mm bolts(i forgot) on each side/inside. Remove those & dont forget to remove the 4 screws on the corner ends of the front bumper & it should come off. Once the front bumper is off you can remove the :WHOLE: headlight… :rockon:
http://g2ic.com/forums/showthread.php?t=92984
