i got a jdm clock and need to know how to take the stock one out, does it just pop out? i dont want to try it just in case theres a different way, thanks
I might be wrong but it should pop out. There is a clip on each side i believe?
There is two metal clips on either side of the clock, just slide some small slot screwdrivers in on either side, push inwards (towards the clock) and pull. It should pop out.
The hardest part of the whole procedure is not marking up the dashboard while doing it.
what the different between your jdm clock an the clock that is in there
i believe the jdm has amber numbers instead of white
some jdm do most jdm dont
you couldve made them amber yourself -__-… but yeaa the clock prys right out
And how would you do that?? i took mine off today and the clock cip is one piece that lights up. If you think you could change the bulb,there is non.
Yea it east pretty easy to change the color on them but it is nice to find 0ne all ready done
How would you change the color? Do you just get a new clock chip and put it in or what?
U can actually jus put like color film on it and it lights up that color!
sum people do that
Good point. Never thought of doing that.
i got it out you have to do it slowly cuz the plastic is kinda weak, but it just pops out…i like the amber better cuz i hate the bright wight light, plus i only paid $10 for it
got lucky getting that amber clock they are hard to find good score
