How to swap DC seats into my DA??
my DA seats are worn out and want to swap in DC or ITR seats.
ive searched but didnt find anything helpful.
can anybody help with an instruction manual w/pictures?
rail swap, attaching auto seat belts would be great…:wave:
if anybody else needs info, BUMP!! if ya feel me!
you know you were gonna get this response… :search:
try typing in g3 seats.
i already searched. but found nothing but for sale thread and del sol seats…Glok was gonna up date soon
“Nice, i was looking at both seats and this seemed to be the only way to do it. Glad that someone else did it successfully, im gonna do it and take some pics.”
but hes lagging, need something to do this weekend!
based on what i’ve read b4 about dc seats in a DA, only 2 bolts will line up and u’ll be lucky to fit 3 bolts in w/o modifying the stock rails on ur stock DA seat…i may be wrong but i was going to install dc seats in my DA b4 but changed my mind cuz i didn’t wanna rock the seat with only 2 or 3 bolts bolted in…too dangerous…anyways, i’m sure u’ll find the writeup…just search for DC seats or 94+ integra seats…good luck!!!
take it easy on him guys
the search is gay with words that are less then 3 letters
so searching “G3” or “DC” or “94” comes up with no better results then if you just type in seat.
if you specify which section you want to search then this happens…
if you search for “DC2 seat” in a certain section, it comes up with over 200 results because it randomly decides it is going to search for “DC2” OR “seat”. even if you type “DC2 AND seat” it still searches for “DC2” OR “seat”.
I have been trying for over 5 years to figure this one out
I have G3 seats in my G2 right now
You are right. only 2 bolts line up correctly, you got to mangle the seat to get the 3rd one in, and to get the forth you have to drill a new hole in the seat rail.
I finally got a set of G2 seats laying around
So i decided to take them apart and compare them to my G3 seats, well… as you guessed it is not just a straight swap… the rails bolt up completely different.
So if anyone has some useful criticism, besides SEARCH or :search: please, by all means,
squeezethis:
what did you get when you searched for G3 seats? how did that work for you? Can you link me to the thread that you found that answered all his questions? If you could you would be ending my 5 year search for this info, which as you can imagine while i have the seats apart, would be extremely wonderful.
[QUOTE=Greenbling;1812703]
squeezethis:
what did you get when you searched for G3 seats? how did that work for you? Can you link me to the thread that you found that answered all his questions? If you could you would be ending my 5 year search for this info, which as you can imagine while i have the seats apart, would be extremely wonderful.[/QUOTE]
wow i got tore a new one on that one. yea i did forget how bad the search is. but seems as if u already bumped a thread that has it. maybe i should suggest “rail swap” as a topic search. that ok mr?
ok just tried searching “rail swap under interior” and ya that works.
Greenbling – here’s the answer to your prayers. Well, sort of… it’s not perfect, but it’s better than what we have here. Google has indexed everything, rendering most sites’ “search” buttons a waste of time. Go to google, type in this:
G3 seats site:g2ic.com
or
“G3 seats” site:g2ic.com
:slight_smile:
not trying to be and ass but goddam search… there is even one topic below u asking to use g3 seats… dam read… u can also search del sol seats also…
http://battlecat.8m.com/DelSols_install.htm
http://www.g2ic.com/forums/showthread.php?t=174925
yo stealth ive already searched and del sols are way different.
Ricextacy: are u tryin the one with the del sol seat right up?
TEG: yeah i looked at it
TEG: but see… back where the hinge for the back is different
TEG: i dunno
eg, del sol, dc, ek are all the same bracket… i used the same link from battlecat to do mine rail swap and it work for the dc seats, alittle bit confusing but u’ll come to understand after reading it over and over… like i said i would make a how-to thread but i already did it, but mite be changing the rails over to some newer seats, so i mite or mite not do it… if i do i will post up a how-to… but just read the guide from battlecats to get a better understanding on wat to do…
do it for me!:angel:
