How to take of rear hatch?
I need to do this so that I can paint in the jambs. Last time I tried to take it off, I had no clue how to get at the bolts? Any ideas, suggestions, or how did you do it if you did it?
remove the headliner trim and it will be able to sag down a bit…the four nuts are inside there (2 on each side). and then its up to you on what to do about the wires on the corner…
