Wondering the correct way to test my spark plug wires, with a ohm meter
Correct way?
You can probably figure out how to use an Ohm meter with a quick internet search.
The wires should measure 25kOhm resistance maximum at room temperature. However, you will still have to do a visual inspection to make sure there are no cracks in the insulation.
I just didnt know what readings i was looking for
its about 3k to 4k Ohms per foot. if i remember correctly.
