i need help with my hatchback is kind of out of place is more to the right, my question is does anyone out there knows how to fix it …or how to center the hacktback? this sucks. any help or ideas are welcome…thank you.![]()
:wrong:
[B]POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. Read each forum’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted. [/B]
And for your question, I don’t know :bored: Got pics?
there are bolts under the headliner (two on each side) that hold the tailgate down, loosen them up and move it around, probably need 2 people to do it right.
