a howling noise is happening when i take turns…I was thinking the bearings…im i right?
back right…
It sounds like it. Check your brake pads too but it’s likely to be your bearings.
The rear bearing/hub assembly swap is pretty simple. The only problem is the price of the assembly.
howling?
Did you leave your dog in the trunk?
But seriously though, I’ve heard grinding and clicking but howling?
Lemme know if you figure exactly is the cause.
REd
f’n werewolfs…
