howto remove rear struts
easiest method of getting rear struts out
i just did this tonight and it was easy. All you got to do is remove the top strut bolts and the lower strut bolt. Then just push down on the brake assembly and it should pop right out.
take off the upper control arm if you want to make things much easier
right on
