Hurry?!!!! Bad Teg Problems!!!!
HELP!!! My teg was smokin last night on the way home really bad under the hood, around the engine!!! But I couldnt pin point the problem! Also I noticed fresh oil spots around my driveway! HELP!!! What could be wrong!
make sur the oil spots are yours. put a piece of cardboard under your car at night. check pcv hose , oil filter , v-cover gasket?
You need to find out where the oil is coming from first. If you cant figure that out then you will want to go and steam off our engine so you can see where the new oil spots appear.
Where do you see the most oil??
Later,
BR
well im sure they’re mine, i had a leak about 4 months ago, but it was the oil drain plug… so i replaced it… problem solved… until TONIGHT?!
i would say valve cover gasket, it might be leaking down anto the header causing it to smoke and also leaking down your drive way…
