has anyone used HX wheels on their Teg? If so…did you have to use spacers?
You can either use spacers, or shave some material off of your caliper bracket.
Spacers are the non-permanent solution.
i shaved my calipers a little and they fit right on …
Im thinking im gonna go spacers. Can I use the kind they sell at like pepboys and autozone?
Yes, just make sure you have enough length on your wheel studs.
i put on 91 crx Si’s lastnight on my DA…they rub on the caliper…i was thinking of going to home depot after work and get some washers…same effect as spacers right?..
also…how would you save the caliper…i mean with what would i shave it…i dont have a grinder…
