I just recently put a 94 GSR swap into my 90 Integra. scince the intake manifold is upside down I cant get a normal intake to work. I custom made one for now but I wanted to know if anyone makes a hybrid intake for this setup. thanx.
AEM makes some hybrid intakes, but I’m not sure if they make one for that application. The other option would be to go with a different intake manifold.
-nino
Geezz… YOU DO NOT MAKE NEW HELP THREADS IN THIS FORUM!!
READ THE RULES AND POST IN THE CORRECT FORUM.
Articles / Teg Tips™ (1 Viewing)
Articles pertaining to G2 Integras and DIY Teg Tips.
[SIZE=“5”]DO NOT POST NEW HELP THREADS HERE.[/SIZE]
http://www.g2ic.com/forums/announcement.php?f=27&a=13
POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. ASKING IF A PARTICULAR PRODUCT IS GOOD SHOULD NOT BE POSTED IN ASSISTANCE, BUT RATHER IN THE PRODUCT REVIEWS FORUM. You may NOT post in the General Discussion forum (or any other wrong forum, depending on your subject) just because you think it will get more attention and you’ll get your answer sooner! Read each forum’s or category’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
