whyd you do it?
what was youre reasoning for going hybrid?
im just doing some pre-suspension-buying-decision-making-research.
thanks:up:
whyd you do it?
thanks:up:
my guess would be if you are running sleeve on coil-overs(Skunk2, GC), you can adjust the ride height to compensate for the shorter shock from the EG/DC body styles.
when using the rear shock from these cars(EG/DC) the shock is shorter, so in theory you don’t really lose that much travel, and since you can adjust for the height difference, you don’t lose much suspension travel and you have a wider range of shocks.
How does that sound?
