when i start my teg sometimes it dies right after i start it then it wont start. turns over but dosnt start. i have 2 leave the key on for about 5 min and then it starts right up like nothing happened. the second prob is that when i start my car my oil light stays on for about 30 sec or longer but less than a min almost everytime i start it but stay off as long as i drive it but as soon as i shut it down and start agin right back on:(
did you check and see if you have enough oil?
Your 1st problem happend to me a while back. Turned out to be a bad igniter. Have it checked.
yeah i changed the oil about 2000 miles ago its right on the money it started right after i changed it im going 2 change it again this weekend and see what happens
thanks for the tip ill check the igniter
It could be the oil pressure switch starting to fail or worse yet the oil pump.Get it checked out either way.
That happens to me when i turn the car off while i am still rolling like right before u completely stop…also happened in the civic i used to have…
