I need help with My da..
OK so few problems,
if there are teg tips for this please atach them to this thread you guys will help me out alot…
  1. I replaced the cluster but i cant get the speedo cable to CLICK into that socket ive tried for hours… is there any trick to that?
  2. My climate control lights dont work, but harnesses are plugged into each other, any help to fix/refurbish that?
THANKS EVERYONE.
http://forums.g2ic.com/announcement.php?f=29
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
As for #2, look in Interior:
http://forums.g2ic.com/tegtips/
